Valve job :confused:
Old Dec 8, 2002 | 02:40 PM
gsrstyle's Avatar
gsrstyle
Nitrous Junkie
Default Valve job :confused:
So what goes on when you do a 3-angle valve job?
Old Dec 8, 2002 | 02:51 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
The valves are backcut at 3 different angles, which is supposed to make for better sealing against the seats.
Old Dec 8, 2002 | 09:28 PM
Brian's Avatar
Brian
the valve seats in the head are cut with 3 angles, a 45 where the valve sits and then two other usually secret angles leading into the port. a good valve job consists of 5 base angles and then blend the seats into the ports.
