DIY: HID Retrofit in an EK
Old Aug 25, 2008 | 06:16 PM
chocolate_bear's Avatar
chocolate_bear
Black magic
Default DIY: HID Retrofit in an EK
Hello all,
I decided to do a HID retrofit because besides the cool look I also do a lot of backroad driving and I hate my shitty aftermarket headlights. I had bought them because I wanted projectors (stock output blows). The output on those headlights were OK, but the housing was way too flashy. Anyways, hope you guys find this helpful.
What you'll need:
- D2S bulbs
- D2S projectors (I used a pair from a TL)
- Wiring harness
- ZKW lens or replica clear lens (optional)
- Shrouds (or you can make your own)
- Ballasts (I used a pair from a TL)
- LED rings (optional)
- Flat head and philips screwdrivers and 10mm socket wrench
- Primer and paint (optional)
- Adhesive/glue
- About 7 hours
1) I had to start off with some splicing so my TL projectors can plug into the ballasts without any trouble.
2) I took my stock headlights apart (by putting them in the oven at 375 degrees for 4min each). I had to cut the stock housing to fit the projectors. I used a jigsaw to cut the housing and a drill press to drill a 3.25" hold in the reflector.
3) Then I tested the projectors in my basement
4) As you can see in this pic, the projectors stuck out too much and wouldn't fit into the car.
5) To fix this, I had to cut into the reflector more which kinda sucked because I didn't want to make a shroud. No, biggie though. Eventually I got it to fit, then I mounted the reflector back to the headlight housing.
6) Now to cover the projector, I had to make a shroud. I used a top piece from those lawn lamps that you can put infront of your house.
7) I used a drill press to drill a hole into it
Old Sep 13, 2008 | 08:57 PM
chocolate_bear
Black magic
8) After some more cutting, it fit nicely into the reflector
9) Here's what it'll look like with the LED ring around it
10) I primed the shroud and painted it with chrome spray paint to match with the reflector
11) For fun, I also decided to mount these red LED's into the shroud. I quickly drilled some holes into the shorud and mounted them. I ended up applying another layer of paint after I drilled the holes.
12) Next I mounted the LED ring to the shroud
13) Then I mounted the shourd to the headlight reflector
14) Next you have to disassemble your front bumper. There is a screw in each wheel well, 7 plastic screws around the grill and 2 bolts under the bumper.
15) Remove the headlights. Each headlight has 4 bolts holding it.
16) I mounted the HID's to make sure they fit okay (and they did)
17) Then I took my aftermarket headlights apart by putting them in the oven for 375 degrees for 4 min. My reason for doing so was because I wanted to use their cover since it was cleaner and more clear than my stock ones. So I just swapped them from the aftermarket headlights to my stock headlights.
18) Here you can see the difference between both covers.
19) Mounting it is easy, there's only 1 secrew required for the aftermarket cover
20) Then I mounted it on to the headlights. Use any strong adhesive/glue to do this.
21) After I mounted the retrofitted headlights I had to do all the wiring which took a bit of time. I wired the red LEDs and the LED rings to the ignition wire that way they light up as soon as I start the car instead of the day time running lights (which are required in Canada)
Old Sep 13, 2008 | 09:00 PM
chocolate_bear
Black magic
22) Put the bumper back on and then you're all done! This DIY might make this project seem easy, but its quite time consuming. It took me a little over 6 hours.
Hope you guys enjoyed this! I really like the way it turned out because the stock headlights are so much nice than the POS ones I had on.
Before:
After:
Here are some more pics of the finished product:
Old Sep 14, 2008 | 11:19 AM
Civic2Scooby's Avatar
Civic2Scooby
pictures don't work.
Old Sep 14, 2008 | 12:04 PM
chocolate_bear
Black magic
yeah, it appears i've exceeded my monthly bandwidth traffic on my photobucket account. You'll have to wait until the 18th until it resets.
Old Sep 18, 2008 | 08:32 PM
chocolate_bear
Black magic
pics should be working again.
Old Sep 22, 2008 | 08:35 AM
chocolate_bear
Black magic
Turned off the LED rings/angel eyes the other day:
Here's a day time pic for those interested:
... and cutoff (sorry, pavement was a little uneven):
Old Oct 4, 2008 | 04:17 PM
kylea24's Avatar
kylea24
this is a awsome diy man, where did you get those covers?
Old Oct 11, 2008 | 07:02 AM
chocolate_bear
Black magic
Thanks... which cover are you referring to?
Old Jun 16, 2009 | 08:13 AM
ENFORCER's Avatar
ENFORCER
Could you give us an update on how these lights are doing? I feel like they might fog up. Just curious.
