HELP! 91 legend only starts when its warm outside
Old Apr 30, 2008 | 07:45 AM
jorge32673's Avatar
jorge32673
Default HELP! 91 legend only starts when its warm outside
My 91 legend will not start in the morning when it is cold outside (under 45 degrees). A few hours later it starts fine. Any ideas?
Old May 3, 2008 | 07:54 PM
ari_one's Avatar
ari_one
When you try to start it when it is cold, first turn off your radio then only turn the key to position II (just before it starts to crank) and listen. Do you hear a humming sound (fuel pump building pressure), if not then most like it is due to a bad main relay (fuel relay).
Old Jul 23, 2008 | 03:58 PM
BilltheButcher's Avatar
BilltheButcher
Witchking of Compton
Spark or fuel? Check those, and see if you ECT is within specs.
