My car doesn't start properly...
Old Nov 17, 2007 | 08:43 AM
canada's Avatar
canada
Default My car doesn't start properly...
Yesterday it seemed like it had some trouble starting up... would turn for a second before turning over. I was low on gas so I figured it was that and filled up. Then when I went to the gas station I left my lights on while I filled up which took maybe 3 - 4 mins and when I got back in it clicked but wouldnt start. I let it sit for a minute then it would try again and it started to turn but wouldnt, and every time I tried right away it would get worse. I had to let it sit for like 10 mins then it started up fine.
Any idea what I need to change next?
Old Nov 17, 2007 | 09:08 AM
v6_accord_jerz's Avatar
v6_accord_jerz
Stupid Power Ball
Most likely your alternator is shot.
Old Nov 17, 2007 | 09:12 AM
canada's Avatar
canada
I also have shoddy electrical inside the car a lot of the times. I figured it was the alternator and not the battery... but I needed a second opinion since I don't know that much
Old Nov 17, 2007 | 09:16 AM
Zackk's Avatar
Zackk
What kind of car is this?
Old Nov 17, 2007 | 09:33 AM
canada's Avatar
canada
91 Honda Civic aka Beater.
Shouldn't be too hard to replace the alternator right?
Old Nov 17, 2007 | 09:36 AM
v6_accord_jerz
Stupid Power Ball
Well it might be in your case. :chuckles:
Old Nov 17, 2007 | 09:39 AM
sinthetiq's Avatar
sinthetiq
take it out and have a shop test it
Old Nov 17, 2007 | 09:40 AM
canada's Avatar
canada
As long as its not super hard i'll go for it. If it's supposed to take 60mins or something it might take me 3 hours... but i'll get it done. I enjoy this stuff and its just a learning thing for me
Old Nov 17, 2007 | 09:41 AM
sinthetiq's Avatar
sinthetiq
its only a couple bolts. 30min tops
check the starter and battery while your at it?
Old Nov 17, 2007 | 09:49 AM
v6_accord_jerz
Stupid Power Ball
There are some shops that can test it with it on. No sense in removing it if it's fine. The Sears around my area used a load tester on my car with it on and it was infact faulty.
