Car is soo hot, and messed I'l never get to the dyno!!!! help please
Old May 19, 2007 | 04:24 PM
madman4you's Avatar
madman4you
Default Car is soo hot, and messed I'l never get to the dyno!!!! help please
OK, first off here is the set up: First gen b16 turbo, in a 91 crx si.
So recently my temp gauge has been going crazy, waving up and down like a roller coaster while I drive, and the car is extremely hot once I stop and check under the hood. So I was told to change the thermostat it might be sticking, or air in the lines. So I replace the thermostat and made sure I removed any air. Car still does the same, except now its worst.
I will be driving along fine until I’m about to slow down and down shift. The car is so messed at idle. While down shifting I’m trying to give it gas to rev it up and it’s slowly going up but power is dieing and then when I’m at a total stop or almost, car dies!! Try to start it up its turning over and everything, (new battery, and alternator) but its almost like there is no fuel...and then after like 4-5 tries it starts and I continue to drive....at least until another turn or stop occurs...and it repeats it self........And all while the temp gauge is going crazy up and down in that wave motion....
Please help guys any info with help.......anything info didn’t inform you with, just let me know what you need to know about my set up and I will reply as fast as I can.
Thanks guys.
Old May 19, 2007 | 04:33 PM
totalimmortal's Avatar
totalimmortal
MalleusMaleficarum
What engine management??
Old May 19, 2007 | 06:29 PM
madman4you's Avatar
madman4you
i dont think that is the issue, im just running the stock b16 ecu......i have a p72 with hondata, however its not installed yet.. i have no wastegate spring in the wastegate. sooo im not really building boost, plus i drive it like a grandma. I think its somthing other than engine manament.
Old May 20, 2007 | 12:37 PM
madman4you's Avatar
madman4you
bump for any more info......even though i pulled the head, rplace head bolts with ARP head studs, changed the head gasket and had the head resurfaced last year i have to do it again??
Old May 21, 2007 | 05:42 AM
primetime's Avatar
primetime
Is your fan coming on? have you checked the coolant level? My gsr was doing that this weekend, i had to replace the fan switch sensor and so far so good, my temp gauge is staying at a normal temp now!
Old May 22, 2007 | 01:08 PM
madman4you's Avatar
madman4you
man i wanted to hard wire up the fan and go for a drive to see if it still would overheat...but now the car just goes into limp mode hard and dies when i come to a stop or if im down shifting to turn the corner......than i cant get it to start....its getting fuel and its got spark......im going crazy here!!!!!!!!!!!
Old May 22, 2007 | 04:57 PM
ED9man's Avatar
ED9man
driver
overheating repeatedly is a good way to blow a head gasket
Old May 23, 2007 | 07:58 AM
primetime's Avatar
primetime
i wonder if he has blown it already?
How old is the thermostat? have you changed the water pump?
Old May 23, 2007 | 07:30 PM
madman4you's Avatar
madman4you
Ok think i got it.....car was dieing due to the new after market fuel pump being shorter than factory one....with even 1/4 tank it thinks its empty. Also the main relay is gone on it i think...that makes sense to why its overheating...fan not turning on..the coolent temp sensor not working....I think everything is ok now...thanks all.
Old May 24, 2007 | 04:59 AM
primetime's Avatar
primetime
what fuel pump did you use??
