getting through the firewall
what would be the easiest way to get through the firewall on a 93 prelude with an 8 gauge wire? will I have to drill a new hole? everything I tried so far doesnt really work out.
if it is an automatic then you can drill through the clutch-plate area on the firewall and use a plastic in the hole you drilled to keep the sharp edges from cutting into the power wire...
unless of coarse you can find a grommet to use.
