p28 chipped in b18b
Old Nov 14, 2006 | 08:08 AM
Iso187's Avatar
Iso187
Default p28 chipped in b18b
I ganked a OBD1 p28 out of my frineds civic he was selling to get it chipped and use it in my OBD2 TEG. After imediate removal, i connected it up 2 my TEG to see how it ran. I did have a cel light on w/o the 3k rev limit. Everything ran fine (a bit rough from the p28 MAP) I tried to check the engine code (jumper) and it wouldnt spit out code. I figured no biggie. (possible the vtec ecu, on a non-vtec motor?) I took the ECU to on of the only places around where I live that Honda mods, (Western PA, wont give name of place, they dont deserve the plug) and the told me they chipped it and everything was fine. I installed the ECU and the cel is still on, but now i cant rev above 4k. Uppon opening up the ECU to see how well the "professional" shop did, i noticed that they didnt install the 2 capacitors!? Would this be the problem? I have had problems with other ECU's which didnt rev ast 3k and i know that, that is the ECU in limp, but what about 4k??? I got over-charged ($90) for a damn simple solder job, and to top it off, the damn ECU wont work! I have tried several different *.bin's (from p28 to p75) and not one will work. Any help would greatly be appreciated!
Old Nov 14, 2006 | 11:23 AM
Snoopy's Avatar
Snoopy
been there done that
what mods do you have that made you feel you needed a chipped ecu?
Old Nov 14, 2006 | 12:10 PM
Iso187's Avatar
Iso187
For the time being, intake, exhaust. Once the first snow, and i pull it off the road, I would liek to start building my motor and dropping it in ASAP!:
b18a GE sleeved 84mm
GE rods/arias piston 9.5 c/r
garrett gt30r
try make use of Crowler 403's i alread have
Limmited Slip Diff
3" DP... you get where im going.
This is my first build, and i want it ti be a damn good one. I have everything, no problems with anything so far, BUT the ECU.
Old Nov 14, 2006 | 12:13 PM
Snoopy's Avatar
Snoopy
you do not need a different ecu with an intake and header. put your stock one back in until you have the rest of that in. at which point you should get something programmable to tune with.
Old Nov 14, 2006 | 12:16 PM
Iso187's Avatar
Iso187
I have had my rom burner and all software, WBo2, everything i need. The ECU is my only obsticle. I would like to get it outta the way now while i have the time.
Old Nov 14, 2006 | 12:18 PM
t3t4delsol's Avatar
t3t4delsol
why the hell are you using a p28 there set up for SOHC vetc like the d16y8
You have a teg your using a b18 motor you need a p72 ecu
Old Nov 14, 2006 | 12:22 PM
Iso187's Avatar
Iso187
Like i said earlier, the shop nearest to me told me it didnt matter on ECU once chipped. You think this is where my problem is? After burning a baseline MAP, shouldnt it work anyways? Please, throw me your input?
Old Nov 14, 2006 | 12:23 PM
Snoopy's Avatar
Snoopy
the best way to determine proper settings is on the dyno. or at least a street tune if you have datalogging. what software are you using?
p28's can be chipped to run any number of engine combo's.
Old Nov 14, 2006 | 12:24 PM
Iso187's Avatar
Iso187
I have both Uber and Crome. Leaning more towards Crome. But either way, if u cant get an ECU to function properly, i can program...
Old Nov 14, 2006 | 12:25 PM
t3t4delsol's Avatar
t3t4delsol
the ecu is not set up to control dohc
