92 Legend Starting Problem
I have a starting problem with my 92 Legend. Starts sporatically, sometimes immediately after hearing a barely audible click behind the firewall (perhaps on the passenger side). It starts eventually everytime, but sometimes it takes more than 30 minutes.
If this could be the "main relay" where is that located? I've checked all relays in the fuse boxes I know of in the engine compartment and they seem to be OK.
Any help?
Any help?
Ah yes the infamous main relay problem... many people have this problem and claim that hot weather helps...others swear by slapping the hell out of it... I would just replace it... but you are going to find that it is a honda dealership part and it's not going to be cheap...
You can find it behind the drivers side dash... It's a grey box bolted up behind the heater vent with a 10mm... if you have small hands, you can get it out without ripping your dash apart... I believe it's attached to a 14 pin connector, so make sure you unplug the right one...
