Help Fixing Rust On Back Corner Panels
i never used bondo or any thing, here are some pics, it would help alot it someone would look at them and tell me the easy way to fix that the best i could.Because im getting it ready to be painted.thanx
Originally Posted by sherwood
strip it, cut out the rust, bondo, sand.
i have a little bit of a clue however.
1. sand paint off surrounding area
2.cut out the rust if its through the metal or if its surface rust, grind it off.
3. patch the metal with MORE metal not bondo if it is through. then skim coat it with some high quality bondo... if it is not through, skim coat the area with bondo.
4. then sand it, prime it etc..
it is a waste of your time in the long run when you just slab bondo over rust. it will come back to haunt you if you dont do it right.
Originally Posted by lowbrow
Umn... you just said the exact same thing as sherwood - sorry you wasted your time registering just to :repost: what he said.
Originally Posted by Mbe25
it says nothing about replacing the metal that the rust has consumed.
way to make friends here buddy with the way u stated that previous comment
h:but yes u are correct... u have to cut out the rust area, clean the surrounding *i cant remember what the stuff is called but it helps prevent future problems* weld, replace, bondo, sand, etc....
