gasket prep??
Old Mar 15, 2006 | 05:14 AM
rugsr's Avatar
rugsr
How do my taillights look
Default gasket prep??
im going to put on my gaskets tonite and was wondering if i need to prep them in any way. like with oil, hondadbond, etc.
they are the valve cover gasket, oil pan gasket and 4 spark plug gaskets.
i have some generic hondabond from a parts store that im gonna use. i know i need this on the valve cover gasket(BTW how muchand where, all around?) but do i need this on the oil gasket? do i prep them with oil?
Old Mar 15, 2006 | 08:32 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
Put some hondabond on the corners of where the gasket seals. Other than that, the gaskets can go on dry.
Old Mar 15, 2006 | 09:43 AM
rugsr's Avatar
rugsr
so just the corners then. not all the way or on the cam humps?
Old Mar 15, 2006 | 09:48 AM
Provocateur
On permanent hiatus
Just the sharp corners.
Old Mar 15, 2006 | 10:01 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
On paper gaskets I always rubbed a little oil on them.
The rubber ones you're installing should be installed exactly as Shmoo has explained: hondabond/RTV on the sharp corners like in the edges around the cam hump(s) on the head and crank hump(s) on the oil pan.
hih
Old Mar 15, 2006 | 10:35 AM
Provocateur
On permanent hiatus
On the intake manifold gasket especially, you want to coat it with a little oil since it is made of cork and will stick to the head and manifold after some time.
Old Mar 15, 2006 | 12:16 PM
rugsr's Avatar
rugsr
lol i cant even get the old one off. ive broken about 5 blades trying to do it. SUX
Old Mar 15, 2006 | 12:47 PM
Provocateur
On permanent hiatus
I had to use a dremel and gently sand it off. Most of it was stuck to the head, but it was off already.
Old Mar 15, 2006 | 01:10 PM
rugsr's Avatar
rugsr
shit schmoo, i never thought of that! thanks, ill try that!
better be careful and not hit the head right?!!! hah bad news im sure
