im thinking of doing this
i was looking around for an engine and i decided to look on ebay to see what they had but on there i saw blocks and heads for so cheap so im now thinking of getting this block and head and then building the motor what you guys think. also would this be a good setup if i did LS/Vtec instaed but i want to still boost i want to know if there will be any problems thanks
http://cgi.ebay.com/ebaymotors/B18-L...QQcmdZViewItem
http://cgi.ebay.com/ebaymotors/Integ...QQcmdZViewItem
ur looking at spending a couple hundred to have those parts ready... LS-V is a huge build and honestly i dont think your ready to go into it.. research it ... check out "G2ic.com > teg tips > engine > LSVTEC build" read that... and if you fully understand everything they say... feel free just be careful
That is a regular B18 head. I don't know if you're either unaware or don't plan put together an lsvtec anytime soon but you will need a head with vtec in order for it to be lsvtec. And If you knew that already... well... my apologies.
Parts:
http://www.c-speedracing.com/howto/lsvtec/parts.php
How-to:
http://www.c-speedracing.com/howto/lsvtec/lsvtec.php
as of boosting... i dont know. never even had a turbo car.
Parts:
How-to:
Parts:
How-to:
Parts:
How-to:
yeah... like he said... u would need a GSR/type r/b16 head to be able to make it work. and like i said... read and learn everything u need to know to do it and be SURE that u know what you are doing before attempting such a difficult build
Originally Posted by aboobybobpleez
lol tegbooster is always gets nervous about the ls-v build
Originally Posted by hachacker5024
i know that head isnt a vtec head and when i do it i am prolly going to get the LS-vtec kit online
-Vtec head (gsr/type-r/b16)
-Non Vtec block (CRV:b20 LS/RS/GS:B18)
-lots of fun stuff (new oil lines, cams if needed, valvetrain if needed)
-a few days of back breaking labor
what the LS-Vtec kit you've seen is, is probably just the head gasket replacement that will reroute the oil to the Vtec selenoid which comes on the VTEC heads.... search "howstuffworks:vtec" to really understand how a NON-Vtec head can never produce Vtec...ever
What tegbooster said + 1. It probably took me a week to build my setup and about 4 months of research, reading everything I could get my hands on ls-vtec builds before I even decided to start my build, I also asked questions to make sure I was going in the right direction with it.
Do as much research as you can and make sure your confident in what you are doing before you attempt this build. I used the GE LS-VTEC kit on my engine, it's a nice kit.
