How can i get better range on my alarm?
My alarm is an aftermarket but I bought and installed it by Honda. So the problem with the alarm is that the range sucks! I literally have to be at least 10 ft from the car inorder for it to arm/disarm. Is there ANY way i can get better reception? What if i connect the alarm's wire antenna to the frame of the car so in that why the frame acts as the antenna too? Also i've seen brands like Clifford where they have this sorta external antenna. Could i some how connect that? This alarm is getting me frustrated and changing it is becoming an option. TIA guys!
What brand of alarm you have ? Check with their website and see if they offer extended range antenna for your alarm.Most of the antennas are glass mounted like what I have and it works 400 ft away. If you can download the instruction on how to install the alarm, you will find there where you can hook up the extended range antenna. Hope this help bro.
i was gonna say the same^
on another note, you can use your body to extend that range. hold the remote under your chin, take your other arm and point to the direction of your car with you longest finger. take the opposite leg from the one you are holding your remote with and stick it as far back as you can. as you press the button, kinda hop in the direction of the car.
i think the remote range depends on the brand of alarm, not the antenna. correct me if im wrong. I have alpine alarm, sec-150, the remote range is too good to be true. 10 times better than the OEM one i had. with alpine, i can remote my car from the 4th floor and of course, it's a straight line distance with no obstruction. alpine rocks
I have a Crimeguard alarm that I bought off of Crutchfield, I took the interior molding off of my driver side interior and ran the wire up by the roof, my dad came home one night while I was taking my dog out and he said to see how far I could get before I couldn't turn it on or off anymore. Got to the end of my street from where the car was parked, at least 100 feet. The higher the antenna wire is on the car, the better the range, cause it has the least obstruction, or so I'm told.
you probably look like this: :joshers:
remember that RF signals act differently than other electrical signals. although connecting the antenna to the body of the car may create a larger surface area for the signals to be routed through keep in mind that for the most part you are changing the antennas physical makeup which may just screw it all to ****....not to mention the body is probably going to be at ground anyways so it wont work at all. routing it near a window is a much better idea. extending the length of the antenna, not the area, is a decent idea. for the low frequency signals that car alarms use extending your antenna length will probably work pretty well.
