cam gears while doing timing belt
Old Jan 5, 2006 | 08:44 AM
rugsr's Avatar
rugsr
How do my taillights look
Default cam gears while doing timing belt
well, im gonna be doing the timing belt real soon. and i was wondering if i should go ahead a put in new cam gears. I going turbo now and would it be worth it to get the cam gears AT ALL. Eventually id like to build the motor. like over next winter. should i wait or not
thanks
Old Jan 5, 2006 | 10:02 AM
Brar's Avatar
Brar
well when u replace timing belt u have to time it and when u install cam gears u have to time it...so doing both at once wouldnt hurt. u might as well replace the cam shafts while ur in there. good luck
Old Jan 5, 2006 | 12:37 PM
rugsr's Avatar
rugsr
y the GSR shafts are fine. better to run those then other i hear, well when going turbo
Old Jan 5, 2006 | 12:38 PM
rugsr's Avatar
rugsr
another thing is, will i see some gains with the turbo AND the GEARS. worth the $
Old Jan 5, 2006 | 01:53 PM
tegbooster's Avatar
tegbooster
Resident Ninja-photo'er
without moving the gears...you'll see no difference....if you were to actually USE them...they can help your performance...not sure of gains though
Old Jan 5, 2006 | 10:34 PM
rugsr's Avatar
rugsr
u mean like advancing them?
Old Jan 6, 2006 | 02:50 AM
tegbooster's Avatar
tegbooster
or retarding...yes
Old Jan 6, 2006 | 03:51 AM
honura's Avatar
honura
Seni
Cam gears are worth nothing unless your gonna get the car tuned. If you plan on just running a turbo and running a basic map and calling it a day then do not buy them. If you plan on going to get the car tuned then yeah why not. Maybe the tuner can adjust them to what should fit.
Old Jan 6, 2006 | 07:42 AM
rugsr's Avatar
rugsr
yea i plan on putting it on a dyno and getting it tuned
any suggestions on which cam gears?
Old Jan 6, 2006 | 04:30 PM
tegbooster's Avatar
tegbooster
skunk2, toda, (doesn't omni make some?)
