Problem removing alternator
Old Dec 29, 2005 | 10:28 PM
tahafisaka6's Avatar
tahafisaka6
Default Problem removing alternator
I have a 1990 integra GS, and I have removed the mounting bolts and belt as well as the electrical connection, but I am having difficulty removing the alternator from the engine compartment. Any tips on where this is supposed to come out at as well as tricks to get it out of there would be very helpful. I have already also removed the mounting bracket for the alternator, as well as the tire on the drivers side trying to get it out through that hole there, but no luck.
Thanks.
Old Dec 29, 2005 | 10:33 PM
iownzadc2's Avatar
iownzadc2
Type-DC2
you say you got all the bolts off and you can't get the alternator off? try banging it with a hammer (lightly of course) brass hammer or something.
Old Dec 29, 2005 | 10:45 PM
dubcac's Avatar
dubcac
I
Are you sure you got all the bolts? Belt is off? I'd take a rubber mallet and bang on it like was stated above...or maybe a long flathead screwdriver to try and pry it loose, like how you would adjust belt tension.
Old Dec 29, 2005 | 11:18 PM
XSrcing's Avatar
XSrcing
i think he got it unbolted completely but cant get it out of the engine bay. i guess your just gonna have to twist and pry and hopefully it will fit somewhere.
Old Dec 29, 2005 | 11:33 PM
dubcac's Avatar
dubcac
I
I take it out through the bottom.
Old Dec 31, 2005 | 09:21 AM
turbolowmaz's Avatar
turbolowmaz
You are not going to like to hear this but You most drop the driverside half shaft to remove this bad boy. My boy works at a dealer ship and he told me that too. The real fun is going to get the ball joint to separate from the lower control arm. a puller will work good for this. As long as you are in there you should probadly replace all of the bushing as long as you are down there. just looking at the condition of the bushing will probadly make you sick. Have fun! It took me and a buddy abot an hour and a half to take apart and same to put back. Don't forget to get an alignment then. shit is definately going to be alkinds of out of wack.
Old Dec 31, 2005 | 02:17 PM
dubcac's Avatar
dubcac
I
You absolutely do not have to remove the axle in order to remove the alternator.
Old Dec 31, 2005 | 09:12 PM
karlt10's Avatar
karlt10
I did on my '92 LS, my friend's '93 GS and another's '90 whatever. In all 3 cases there was not enough room in any way, shape or form without pulling the driver's side axle & it's bearing support.
Old Dec 31, 2005 | 09:18 PM
dubcac's Avatar
dubcac
I
I guess maybe I'm gifted? :dunno:
BTW, the helms manual doesn't state that you have to remove the axle either.
Old Jan 1, 2006 | 06:30 AM
FooD2000's Avatar
FooD2000
Still Water
So what's the advantage of our cars running on 3 v-belts as oppose to serpentine belt?
