acceleration question
Old Dec 18, 2005 | 11:56 AM
montemann's Avatar
montemann
Default acceleration question
I have an 89 integra 1.6doch,5spd,155k on it
It runs really good and idles nicely, but when I start to accelarate the car seems to lack power once the clutch is engaged. Im used to v8 camaros so exactly how much should i rev and connect the rpms at, for instance going up a hill from a start can be a chore. It is all stock, no exhaust leaks or anything. I replaced the spark plugs and air filter. would it make a difference in doing wires, cap and rotor if it running so nice and smoothly, also no cel light.
any ideas would be great.
Old Dec 18, 2005 | 01:07 PM
Brar's Avatar
Brar
try downshifting?
Old Dec 19, 2005 | 08:42 AM
KaBlookie's Avatar
KaBlookie
4-doors ROCK
when you're driving around, try to keep the revs above 2k for the most part. If you're in 3rd gear revving at 1300rpm and you hit the gas, you're not gonna get much acceleration. if you're going up a relatively steep hill, and you're in no rush, shift at around 4k-4.5k rpm.
our low-displacement 4-cylinders aren't big on low-end torque
Old Dec 19, 2005 | 10:50 AM
BtTurboM3's Avatar
BtTurboM3
hes right....just give it more rpms and it will have more power.....espeicially on hills
