Gsr or type r? [DC4 (?) contemplating swap]
Old Nov 29, 2005 | 07:02 PM
AcuraLsSE's Avatar
AcuraLsSE
ASE Certified
Default Gsr or type r? [DC4 (?) contemplating swap]
when i do my engine swap what engine should i put in? Right now i have a b18b1. One of my friends told me that the gsr was better to build off of
Old Nov 29, 2005 | 07:06 PM
1turbodc2's Avatar
1turbodc2
got boost?
depends what u want to do, be more specfic as to what your future plans are boost, all motor, etc.... your budget
Old Nov 29, 2005 | 07:33 PM
^agreed it depends on wether u wanna go all motor or boost....i would have to say go with a b18c1 if u wanted to go boost because its basically cheaper to purchase initally and ur gonna wind up changin a lot of parts in it. and really if u wanted to go boost, id think about stickin with the b18b1 block and doing a ls-vtec setup with a built lower end.
if you want all motor well the b18c5 would be better cuz ur already gettin a higher compression ration...
Old Nov 29, 2005 | 08:24 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
keep the LS motor and boost that summbitch. they like boost.
Old Nov 29, 2005 | 08:29 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Yes, I would boost it. Or do an ls-vtec conversion for much less than one of those motors.
Old Nov 29, 2005 | 08:41 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Moved to Hybrid Forum...
https://www.honda-acura.net/forums/s...d.php?t=203947
That link explains why.
Old Nov 29, 2005 | 09:01 PM
AcuraLsSE's Avatar
AcuraLsSE
ASE Certified
about how much would the ls-vtec conversion cost me? And about where would i stand for hp tq?
Old Nov 29, 2005 | 09:46 PM
Provocateur
On permanent hiatus
You would have to buy the vtec head plus a golden eagle conversion kit for the basic conversion. If you want a GSR redline, you should think about some stronger rod bolts for added security. The ls-vtec setup will have around the same compression as a GSR motor with a little extra torque.
