you don't "hear" vtec. you "hear" the butterfly valves (secondaries) opening. primaries open way before that. D16z6 is near the same as the D16Y8 at 4800 RPM's with secondaries at 5200 RPMS
Thank you.
I guess i was way out of line to think 4800 huh?...ha
Well, before i asked i just made a VTEC Light to be sure because i got a lot of diffrent responses. I have a d16z6 and my VTEC kicks in at 4800 RPMs. I made a vtec light for my buddy that had a y8 and his went in at 5500 RPMs.
ok. cool. thanks guys. that really helps. now do you consider having a V-AFC a Must? and how soon do you prefer to engage your VTEC?
i wouldn't spend the money on a VAFC, i would just spend the money towards a hondata s200 w/o boost for maybe $275 and get it tuned to perfection, then you never have to worry about it again. Having a vtec controller does nothing, because you want your engine tuned so when your lower cams stop making power, then the butterfly valves open up and higher cams take over. You want the perfect interchange which can really only be done with good quality tuning !!! good luck
i think that the only butterfly is on the throttle body and opens with the gas pedal not with vtec
