teg radio... HELP
Hey guys I was trying to take my old radio from my teg today.. but somehow I juss didn't know how to get that out...could you guys give me an easy procedure to do that... I need to know where I should start...
any suggestion would be appreciated.. thanks
basically....
1)your center console is in 3 pieces which extend to the bottom of the radio you need to remove the piece directly under the radio...kinda difficult but there are a couple bolts under the ebrake that once removed the rest of it is minor screws that just pop right off...
2)once u got all that out of the way look on the back right and back left of the stock head unit cage...u should see 2 very small bolts remove them
3) unhook antenna/wire harness/all rcas or w/e u got hooked on to the head unit and the whole thing should slide right out...if ur replacing make sure u have the proper dash kit or else u'll have a 2" gap between the stereo and anything else..
hehe i worked @ best buy audio install for a year
good luck
good luck
