Turbo on 145k
Old Nov 2, 2005 | 05:20 PM
gordis's Avatar
gordis
Default Turbo on 145k
You think boosting 5psi on a engine with 145k miles is ok? Should I do a compression check to make sure?
Old Nov 2, 2005 | 05:23 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Get a compression and leakdown test before you do anything. That will tell you the condition of your motor. If the results are good, go for it.
I have 142k on my motor and am boosting 10 psi, so mileage really doesn't matter as long as the car was taken care of.
Old Nov 2, 2005 | 05:25 PM
gordis's Avatar
gordis
sweet. i realized n/a was gonna take way to long and too much money to do. i realized i could peice my own kit for less than 1k, and i would get more power out of it. could i get the compression and leakdown test at any autoshop?
Old Nov 2, 2005 | 05:27 PM
b20hatchy's Avatar
b20hatchy
EM1 Crew member #74
Yeah i agree with schmoo do a leakdown and compression check and if thats good then go for it. Depending on the motor for the pounds of boost
Old Nov 2, 2005 | 11:24 PM
Provocateur
On permanent hiatus
Yeah, you could. They also sell compression and leakdown testers at autoparts stores if you want to try and do it yourself.
