B18c1 Rebuild opinions (m22xx/jdm itr pistons)
Hey guys,
My motor has been eating oil so I am just going to get it rebuilt. Here is my planned setup, any suggestions/comments would be appreciated. I plan on buying from online vendors and bring it into a local shop for them to install.
jdm itr pistons(p73) on stock gsr rods
arb rod bolts
aebs head studs
rocket m22x cams
Supertech flat-faced nitrided valves/springs/retainers
blox IM
maxbore my gsr tb or purchase itr tb
comptech icebox/stock itr intake arm
act hdss/fidanza fw
p28/obd2->1 harness/hondata
hondata im gasket
Full gasket kit
acl bearings?
buddy club cam gears
jdm itr valve cover (bling bling)
Currently running aem cai/oem jdm 4-1/rs*r exhaust.
arb rod bolts
aebs head studs
rocket m22x cams
blox IM
act hdss/fidanza fw
hondata im gasket
Full gasket kit
acl bearings?
Good setup...I'd personally go OEM bearings though. Also, I don't see the need for valves unless you plan on going high boost at some point.
Originally Posted by centerforce99
Sounds good, but if I ever had the chance to rebuild I think I would go w/Type R guts.
Your OEM rods are fine with the ARP rod bolts. OEM valves will be fine too. Flat faced valves will raise compression very slightly, but the difference is negligible. You don't need stronger valves, but lighter valves will move a little faster.
It would be like running any other USDM B16 piston...and yield nearly the exact same compression as the JDM ITR pistons...11.37:1 versus 11.36:1. Running a JDM B16 piston (p30) will bump to 11.59:1.
