omg stupid noob installer
Old Sep 8, 2002 | 04:43 PM
Coupeman's Avatar
Coupeman
Default omg stupid noob installer
best buy kid (outside not under store supervision) helped me install my ****... 2 200 watt RMS rockford XLC 10s and an alpine v12 400 watt continuous amp and when he went to plug in one of my rca cables into my amp, he brok off the circular metal piece on the plug... so only one sub would hit... so i assumed when i went and got a new RCA cable the next day, all would be fine, but ohhh no... when i try to plug the RCA cable in, it cannot fit, he fugged up the jack itself on the amp!
possible to fix? i hope so
Old Sep 8, 2002 | 05:17 PM
b00gers's Avatar
b00gers
post a pic of the problem....how does it not fit? and how do you exactly mess up the female part of a RCA connection?
Old Sep 9, 2002 | 05:13 PM
fastball's Avatar
fastball
A little chin music
From: Cleveland, Ohio - Rock 'n Roll capitol of the World
If the male piece is stuck inside the hole (please, no jokes), you can open the bottom of the amp and take a small eyeglass flathead screwdriver to push it out from the inside. If the female part of the RCA is busted off, you need to replace the whole RCA jack. If it is under warranty, they MAY fix it (don't hold your breath, though). If not, you can find that part at a place which sells electronics parts (or Radio Hack) and replace it yourself. If you have some decent soldering experience, you shouldn't have too much trouble. Just make sure you remove ALL the screws holding the amp board to the heat sink, and all the scews around the jacks.
Old Sep 9, 2002 | 08:42 PM
LjN_728's Avatar
LjN_728
hmm...yea seems like u broke the outer connector or ring of the rca plug. Even if u attempted to solder that, it won't help. That's a pretty delicate area that. try this...put the rca cable in the plub and using ur hand, push it in the keep it in there. see if both subs hit. if so u can either go back to Best Buy and try to get a new one or do it the ghetto way and tape the sucka in!
Old Sep 18, 2002 | 05:13 PM
Fujiwara Takumi's Avatar
Fujiwara Takumi
It's my first day.
mm...pics?
and yeah, this is an easy solder job if necessary, but take it back if you can.
Old Sep 19, 2002 | 04:51 PM
SGImport's Avatar
SGImport
did you buy the extended warranty? no questions no hassles
Old Sep 21, 2002 | 06:01 PM
seth90dx's Avatar
seth90dx
Default Re: omg stupid noob installer
Stories like these make me :barf: then I think, hey at least its not my **** :gives:
Epoch
May 21, 2006 02:57 AM
LT
Dec 16, 2005 02:19 PM
Polipinay
Jan 25, 2005 12:50 PM
Falkor
Jan 23, 2005 07:20 PM
xxjustimajinxx
Dec 20, 2003 10:08 AM
