Remove "lx" emblew
Old Sep 18, 2005 | 05:57 PM
takume's Avatar
takume
Default Remove "lx" emblew
Hi all, I remove the "lx" emblew by using dryer as most of the people recommened. But, maybe i didn't do it right. I leave a thin layer of those sticky thing on the surface which i couldn't peel off. Any suggesting to clean that area?
Old Sep 18, 2005 | 06:24 PM
jschmid's Avatar
jschmid
Get some "Goo-gone", or WD-40 will also work. Just make sure you don't use anything abrasive, and after using any products clean thoroughly, and wax the area.
I used Goo-gone, worked fine. Got mine at Home Depot.
Old Sep 18, 2005 | 09:43 PM
lk21joker's Avatar
lk21joker
AnotherAccordOwner
i used alcohol first, then i used acetone. The it left a shadow on the paint, then i wax it a couple times, woosh...gone.
Old Sep 18, 2005 | 11:48 PM
aux's Avatar
aux
More Black on Black Crime
ditto.
Old Sep 19, 2005 | 06:48 AM
takume's Avatar
takume
thx for the help
if it works fine, then i will go ahead remove all the emblems on my car
Old Sep 19, 2005 | 07:01 AM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
If you do use goo-gone or WD-40 remember to immediately wash and wax the treated area...that shit probably eats clearcoat like it's nothing.
Old Sep 19, 2005 | 09:51 AM
takume's Avatar
takume
wait, u mean after i use goo-gone or wd-40, i need to wash( just some water, i guess) and wax right away?
Old Sep 19, 2005 | 09:54 AM
won't the alcohol destroy your clear coat? :eh: that's like wiping your car with a brillo pad.
98CoupeV6's Avatar
98CoupeV6
No wash it as you would normally wash your car, with a car wash concentrate mixed with water. That shit is going to eat through your wax and then the clearcoat if you let it sit for long enough, that's its job.
Old Sep 19, 2005 | 09:55 AM
98CoupeV6's Avatar
98CoupeV6
I prefer steel wool h: Which is actually a surprisingly handy tool in cleaning chromed and aluminum surfaces (ie exhausts and my Coupe door sills)
