Andy
Old Sep 5, 2002 | 09:57 AM
sleepin's Avatar
sleepin
Default Andy
I think I remember you doing this. GSR rear brake swap onto a 92-95 civic chassis.
What are all the parts I require for switching from rear drums to rear GSR discs?
Also, will a Comptech rear sway\lower tie bar combo for a 94- Integra work on a 92-95 civic chassis?(given that I have integra rear LCAs)
Thanks in advance.
Old Sep 5, 2002 | 10:39 AM
dubcac's Avatar
dubcac
I
LCAs, trailing arms, hubs, brake setup, and ebrake cable.
And the comptech sway bar will fit.
Old Sep 5, 2002 | 10:45 AM
sleepin's Avatar
sleepin
Thanks, thats all I needed to know.
Old Sep 6, 2002 | 06:36 AM
Andy's Avatar
Andy
Hybrid Forum Moderator
Default What's up?
Technically, all you really need is the trailing arm itself (the huge ass piece everything bolts to) and the complete brake assembly, including the hub, rotor, caliper, e-brake cable and rubber line (or stainless replacement). The LCA is a good idea from a GS-R as it has the mounting point for a rear sway bar, but it is not nessicary, you can re-use your stock one. If your going to use the Comptech unit, you will most likely need them anyway. That also should bolt up, but I've never tried so I can't say for sure. Seeya.
Johnny Tran
Engine Swaps, Tech & Tuning
Jun 24, 2002 07:29 PM
undrgrndhaqer
7
Jun 22, 2002 10:31 PM
