2ohm vs 4ohm type r's
Old Jul 24, 2005 | 10:19 PM
Chizzy's Avatar
Chizzy
Default 2ohm vs 4ohm type r's
Is there any disadvantage to having a 2ohm sub then a 4 ohm one? is there any difference between them? They are both the same price..
Why I'm wondering is...
The alpine mrd-m605 which i'm most likely going to get puts out 600watts @ 2 ohms and 400watts at 4 ohms. Which will sound better or will the sound the same? the 2 and 4 ohm type r's can each carry 500 rms and 1000 peak..is it better to under or overpower them?
Old Jul 24, 2005 | 10:21 PM
jdmcd5accord's Avatar
jdmcd5accord
if u overpower them u'll blow them...
Old Jul 24, 2005 | 10:35 PM
Chizzy's Avatar
Chizzy
It's actually a 1500watt peak. There's no way I would blow them with 600 rms watts I'm guessing..
Old Jul 24, 2005 | 10:41 PM
jdmcd5accord
u need 2 be more clear about that i though u ment the max rating on the subs
Old Jul 24, 2005 | 10:50 PM
Chizzy's Avatar
Chizzy
I'm sorry I was misinformed aswell, I went on the Alpine site and got correct specs of the subs and amp.
The two different subs power handling are the same:
# Power Handling Capacity (Peak) : 1500W
# Power Handling Capacity (RMS) : 500W
The amp is rated @ 600RMS @ 2 ohm and 400rms @ 4 ohms
Old Jul 25, 2005 | 09:42 AM
b00gers's Avatar
b00gers
If I remember correctly, the Tpe Rs are dual vioce coils. So if you want a 2OHM sub, you need to buy the 4OHM...if you want a 4OHM sub, you will need to buy the 2OHM sub.
With that amp, I would buy the dual 4OHM sub and wire it into 2OHM so you can run the amp at 600 watts. You are not going to blow the subs with an extra 100 watts if you know how to set the gains correctly.
Old Jul 25, 2005 | 09:49 AM
Chizzy's Avatar
Chizzy
why would they say 2ohm if it's actually 4ohms? I believe you it just pisses me off..
Old Jul 25, 2005 | 12:03 PM
97teg's Avatar
97teg
How many subs are you going to run? That will also determine which one you want.
to get a good explination go to
http://www.bcae1.com/
read #8 #12 #38 #58
If you go to jl website in the tutorial website they also have good info about dvcs and how to wire them.
Old Jul 25, 2005 | 01:16 PM
b00gers's Avatar
b00gers
Thats where DVC (Dual voice coils) comes in. They have 2 voicecoils. Each voicecoil is as they state. But when you wire the coils together (parallel or series type wiring), it will change the OHM load (impedance).
Old Jul 25, 2005 | 10:25 PM
Chizzy's Avatar
Chizzy
just one sub
