rsx fog lights
Fog lights aren't meant to be used with High Beams, the dispersion pattern is low and to the ground to cut under the fog, high beams in the fog are almost useless because of lighting up the haze and not cutting through it. If you want additional lighting with your high beams get driving lights.
Originally Posted by gmjg
does anyone kno how to make the oem rsx fog lights come on with the parking lights and the hi-beams
thanks
thanks
here is a wire you need to cut and slice
I-MOD is the one that came up with this mod which will let you turn on the lights while having your parking lights on.. and it will flash with you if you have it on when you press the lock button.
