Aftermarket Fuel Pressure Regulator Questions??
Old Aug 29, 2002 | 05:55 PM
jigga008_99's Avatar
jigga008_99
JDM all day
Default Aftermarket Fuel Pressure Regulator Questions??
I have a 93 Del Sol Si with the regular bolt-ons. I was wondering if anyone has an aftermarket Fuel Pressure Regulator on a N/A tuned SOHC D16z6 VTEC. I was planning on buying either the B&M w/ guage or the AEM. Do FPR really increase hp?? Can you feel and tell the difference in your car?? What are the downfalls to a FPR other than burning more gas?? What other aftermarket parts should I get along with the FPR?? Does it need professional tuning?? I am not planning anything else major other than headwork and cams. Is a FPR worth the money?? All replies are appreciated!!
Old Aug 29, 2002 | 06:42 PM
qtiger's Avatar
qtiger
I would purchase an aftermarket FPR when you upgrade your fuel system. It is not a good method of fuel management and should not be used as a sole method of tuning.
Old Aug 30, 2002 | 04:19 AM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
FPR's are normally used as a "band-aid fix" for lean running engine, however, if you aren't useing an aftermarket ecu or boost, you may find that you can gain power by LOWERING your fuel pressure with a stock ECU since they typically run a little rich [very little, but it's there], but again, they really should only be used as a tool to make sure your fuel pressure stays where you want when you start upgrading your fuel system.
-Harry
AIM: NDcissive
jack1526
3
Apr 29, 2005 08:25 AM
g2prince
Oct 22, 2003 11:25 PM
g2prince
RSX & 02-05 Civic Si
3
Oct 7, 2003 11:14 PM
SIGMA CHI GUY
Mar 13, 2003 05:35 PM
jigga008_99
92+ Civic/EL & Del Sol
Aug 29, 2002 05:52 PM
