Installing a 15" sub
Old Apr 21, 2005 | 04:08 PM
sharp006's Avatar
sharp006
Default Installing a 15" sub
I have a 15" Audiobahn AW1571SE sub that i'm about to install. I just took off an old Kicker CompVR and it looks as if it is much easier to install than the Audiobahn. I just had to run two wires on opposite sides of the sub but on the Audiobahn it has four different wire plugs on either side. I'm confused now. Does anyone know what kind and how many wires to run from the sub to the box?
Old Apr 23, 2005 | 05:23 PM
b00gers's Avatar
b00gers
Please list the amp model you are using.
That sub looks to be a dual 4OHM sub. It has "4 different wire plugs" because there are 2 separate voice coils.
Old Apr 23, 2005 | 10:54 PM
sharp006's Avatar
sharp006
I installed it yesterday. Although it had 4 plugs on each side (two negative and two positive), all I had to do was parallel wire it. It sounds really good. Now I need a new amp.
Old Feb 16, 2007 | 04:43 PM
shietzitzkien's Avatar
shietzitzkien
i had the same problem with my audiobahn sub. aha. i just played around with it and BAM!! there it was. ha. welp happy you got it working. and gl with finding the new amp.
Old Feb 18, 2007 | 05:43 PM
dleccord's Avatar
dleccord
damn dude this thread is hella old.
