Audio, Security, & Automotive LightingTroubleshoot wiring problems and get equipment suggestions all in one place. Now expanded to include Automotive Lighting
I have a 15" Audiobahn AW1571SE sub that i'm about to install. I just took off an old Kicker CompVR and it looks as if it is much easier to install than the Audiobahn. I just had to run two wires on opposite sides of the sub but on the Audiobahn it has four different wire plugs on either side. I'm confused now. Does anyone know what kind and how many wires to run from the sub to the box?
I installed it yesterday. Although it had 4 plugs on each side (two negative and two positive), all I had to do was parallel wire it. It sounds really good. Now I need a new amp.
i had the same problem with my audiobahn sub. aha. i just played around with it and BAM!! there it was. ha. welp happy you got it working. and gl with finding the new amp.
