ma audio tv trouble
i just bought a ma audio 7 inch wide screen and am having trouble with the sound and the picture rolls over from time to time........does anyone know anything about these things?
Typically the sound from these units suck, no matter who makes them, its a small speaker in the back of the monitor about the same size as the speaker in your cellular phone.
There should be adjustments for the picture on the monitor depending on the model you have. Did it come with instructions? It could be on screen adjustable, what kind of video source are you using to the tv?
how are you "injecting" the sound into your audio system? an FM modulator (if so, thats probably the problem) or an input on an aftermarket deck?? If you are using RCA cables into an input on your deck, make sure to keep them away from the power inverter and all those power cables, they can cause noise in a low level audio signal.
also the screen bounces if your power level drop and gain. you you have any amp in your system that can be pulling power level down to cause the screen to bounce? other wise id say its your rca cables picking up noise from local power cables. keep em apart they dont play well with each other.
-krazymatt
-krazymatt
