Help! Changing Trans Fluid In TL
I ned to know where the transmission refill plug is. I have the fluid drained and cannot locate it. I could refill through dipstick hole, but that is really small. TIA!
I figured it out. The plug was replaced with a fitting for a transmission line as a part of the recall recently served on this car regarding the transmission problem. Instead of just a fill plug, you need to remove the line (secured with a bolt through a bracket), and then you can use a funnel to add the fluid.
