5th Gen Power Steering Rack Problem
Old Mar 14, 2017 | 12:21 PM
Accordian47's Avatar
Accordian47
Default 5th Gen Power Steering Rack Problem
'01 Prelude Base
5spd
115k
I think I know the symptom and even the solution to my problem but I'm trying to see if it has happened to anyone else.
I was getting a pretty noticeable clunk coming from the driver's left over bumps.
Checked the following thoroughly with a prybar multiple times:
-Lower Ball Joints
-Upper Ball Joints
-Upper Control Arms (Mounting Bushings)
-Lower Control Arms
-Sway Bar Bushings
-Sway Bar End Links
-Upper and Lower Shock Mounts
-Springs
-Outer Tie Rod Ends
-Inner Tie Rods
-Steering Rack Mounting Bushings
Alllll of these things checked out
I also did a Dry Park Test (shaking the steering wheel side to side, wheels on ground, engine off)
This pretty much made me instantly identify the problem, the steering rack...
With your hand over the rack boot, (around the rack rod and the body/housing of the rack), you can feel play and can hear the noise coming right from there.
You wouldn't think a steering rack would make noise over bumps seeing as it only moves left and right, horizontally with the ground but Oh it does....
Heres the thing, the inner and outer tie rods checked out, the problem is the steering rack itself.
The "Rack Rod" or the geared rod that runs inside the body of the rack and actually moves side to side has end play.
Its as if the internal bushing that guides the rack rod has failed, but why? There are very little forces applied on the rod in that direction but I suppose it could happen.
This was 100% the cause for the play in the steering and clunking sound over bumps.
SO
I bought a new re-manufactured power steering rack from PartsGeek made by a re-man company called MAVAL. Of all the places I looked for a rack, MAVAL had the best warranty AND was the most expensive (I figured it safe to assume this meant the best product) PartsGeek required that I send in my old rack for a core but the MAVAL rack came with a lifetime warranty.
I got the new rack in the mail, put the new re-man rack in and get this...it has the EXACT same problem, end play on the rack rod. Still no leaks but end play. I called MAVAL and spoke with a guy who said that it was not likely the rack that had play and that I should check out my ball joints, I explained everything I had checked and that I was positive it was the rack. He explained to me that if there was ANY play at all in the rack rod that it would cause the internal power steering seals to rupture and leak. I have no leaks but I do have play.
My only option is to take out the rack yet again, send it back and HOPE I get one back that is functional.
I'm thinking the company who does the re-man fixes all the seals, replaces the inner tie rods, paints the thing and ships it. I'm thinking their testing overlooks rack rod play.
  • Is this true that having ANY rack rod end play will cause leaks? I'm not familiar with the internal seals on p/s racks.
  • Has anyone else had this problem?
  • Am I just missing something? Is there supposed to be rod end play?
Thanks guys,
-Ian
Old Feb 22, 2022 | 11:03 AM
octabeno1's Avatar
octabeno1
I have a 2016 Trail Premium with 85,000 km, a 3" Lift and 285/70/17 Duratracs. The Duratracs seem to have been off balance since I put them on ~ 8,000km ago which has led to some vibrating at certain speeds and I also felt like the caster was off because I found myself correcting the steering often when I was at highway speeds. So I took it in and had my alignment done and wheels balanced and my 4Runner drove like a dream ... for 1 day until I was backing out of my parking space after work going slowly at full lock and heard a clunk. Now my steering wheel is off by about 45* and my wheels are toed in visibly. So I brought it back to the shop that did the alignment and they suggested the Speed Test steering rack might be shot.
88crxTurbo
CRX & Pre 92 Civic
2
Feb 12, 2009 11:38 AM
94blueteg
Jul 7, 2006 07:27 AM
wytiak
92+ Civic/EL & Del Sol
12
Dec 1, 2005 09:21 AM
MrHankey
Accord
8
Oct 8, 2005 11:14 PM
AccordManiac
Accord
Mar 29, 2003 05:55 AM
