Remote Start on M/T
Old Jan 24, 2005 | 08:10 PM
Mario's Avatar
Mario
Default Remote Start on M/T
Ok guys, I am having an Autopage RS850 alarm installed this weekend by a local guy. I want to wire up some sort of neutral safety switch so that way it will detect when the car is in neutral or not. Has ANYONE done this, or does anyone have any ideas? I don't wanna wire the remote start up without this... way too much risk without one, but I'd really like the remote start. Thanks!
-Mario
Old Jan 25, 2005 | 07:11 AM
owen996's Avatar
owen996
I know some alarms have pins you can pull on the brain out depending on if its a manual or automatic transmission. Me thinks you should have asked the guy, or at least looked around a little bit more before buying it.
There prolly is a way to wire up a switch, but I googled two searches and then got lazy.
Old Jan 25, 2005 | 08:58 AM
02AccordBigBoi's Avatar
02AccordBigBoi
The 1 and Only....
if you havent seen it...This thread might help you out.
https://www.honda-acura.net/forums/s...ad.php?t=42547
Old Jan 25, 2005 | 04:24 PM
prodigymb's Avatar
prodigymb
i have an aupoage alarm with remote start. put it this weekend. we could not figure out how to make it NOT start in gear. i really do not see it working. what we did was fool the clutch, but if u leave it in gear and remote start it better hope nobody i stsnading in front of ur car. As far as pins on alarm for manual/automatic remote starts > There are none for the simple reasn the remote start on a Manual is ILLEGAL.
Old Jan 25, 2005 | 04:25 PM
prodigymb's Avatar
prodigymb
Autpage 850 is a pimp alarm tho
Old Jan 25, 2005 | 04:34 PM
owen996's Avatar
owen996
get a lawsuit together and sue all these companies for making illegal products
http://www.nextag.com/Ultra_Start_12...06zzmainz2-htm
http://www.audiowarehouse.peachhost.com/ct_PR1256m.htm
http://store.yahoo.com/spoilers4less/2lcdrestwkee.html
Old Jan 28, 2005 | 04:03 PM
claudio12472's Avatar
claudio12472
Use The Turbo Timer When You Shut The Car Off It Will Stay Running And Then You Close The Door And Lock The Car With The Remote And It Will Shut Off.
Old Jan 29, 2005 | 09:16 AM
lgbr's Avatar
lgbr
Wal-Mart Shopper
Remote start is not illegal on a m/t. It is illegal for a road shop to install it.
Old Jan 29, 2005 | 09:09 PM
Mario's Avatar
Mario
Thanks a lot guys. I am thinking about wiring up a SPST switch, or a magnetic reed switch. Thoughts?
