compression test results
Old Dec 30, 2004 | 12:04 PM
shawn_crx8891's Avatar
shawn_crx8891
Default compression test results
ok so i did a compression test on my b16 because it started to smoke heavily and there is oil in my exhaust. the first time through i got 220, 211, 216, and 205 on cylinders 1-4, respectively. i went back and retested the #1 and got 196 this time, so i tested again and still got 196. i poured a little oil in and retested and it was 225. does this mean i have bad rings on that cylinder? the engine was warm when i tested.
Old Dec 30, 2004 | 12:06 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
That does sound like a ring problem. The numbers don't look bad enough to conclude that is the problem though.
Old Dec 30, 2004 | 12:27 PM
Civic2Scooby's Avatar
Civic2Scooby
according to ALLdata that I have at work, anything over 190 is acceptable for a dry compression test. The numbers will always be better during a wet test, even if you have brand new rings because the oil with seal it that much better. I would also try a leak down test if you have access to the equipment.
Old Dec 30, 2004 | 08:29 PM
BoostedITR41's Avatar
BoostedITR41
it has nothing to do with peak numbers it has to do with how close the numbers are to each other. IMO cylinder 4 is shot
Old Dec 31, 2004 | 01:43 PM
Provocateur
On permanent hiatus
You mean cylinder 1. I agree. The rings look fine in every other cylinder though.
Old Dec 31, 2004 | 02:25 PM
shawn_crx8891
what would cause the reading of 220 the first time and 196 the second and third times?
Old Jan 1, 2005 | 09:37 AM
BoostedITR41
that would be cylinder 4 and if 1 dropped to 196 that may also be junk. make sure you hold the gas pedal at full throttle when you do the tests
Old Jan 1, 2005 | 09:54 PM
FLAT_LINER's Avatar
FLAT_LINER
Ridin Dirty
u dont touch the pedal when u do a compression test do you? i thought u just let it idle
Old Jan 1, 2005 | 10:12 PM
Civic2Scooby
:slap: the car isnt running when you do a compression test. you are just supposed to have the throttle all the way open when cranking to get accurate readings. h:
