which head
Old Nov 29, 2004 | 03:58 PM
sherwood's Avatar
sherwood
I missed Sean
Default which head
i am going to overbore a b18c to 2.0 liters and put it in a crx, now the thing i want to know is which head is better for PnP and or upgrades, the c1 or c5, i heard that the c1 is basically just a b16 head so i was thinking that the b18c5 head would be a smarter choice, yet more expensive
Old Nov 29, 2004 | 04:09 PM
dustimus's Avatar
dustimus
Better golfer than you
no... a c1 head is in its own class. A c5 head is a b16 with a PnP and some beefer cams.
Old Nov 29, 2004 | 04:18 PM
sherwood's Avatar
sherwood
I missed Sean
itr is the c5, right?
Old Nov 29, 2004 | 06:17 PM
BoostedITR41's Avatar
BoostedITR41
B16A and B18C5 heads are cast form the same mold...the ITR heads only differences are cams, valves, and PNP
Old Nov 29, 2004 | 11:07 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
ITR heads come ported and polished from the factory but a GSR head will run cheaper and since you are planning on rebuilding it, that would be the head of choice.
Old Nov 30, 2004 | 10:29 AM
BoostedITR41
it also depends on the compression you want....GSR heads will create more compression than a B16/ITR head
Old Nov 30, 2004 | 11:17 AM
Provocateur
On permanent hiatus
True. But the GSR head is cheaper and you can retain the IM that came with the GSR engine.
Old Nov 30, 2004 | 02:29 PM
BoostedITR41
yeah but if you are goin to all the trouble to build a motor why not pic up a skunk2 IM or an ITB set up?
BoostedITR41
Old Nov 30, 2004 | 05:01 PM
dustimus's Avatar
dustimus
ITBs..... maybe if he had an extra three grand laying around.
