Bushings, worth it?
Old Nov 29, 2004 | 06:10 AM
slvrteg's Avatar
slvrteg
big boys toys
Default Bushings, worth it?
I have a 2001 GSR. I am considering the Prothane Total Kit Polyurethan bushings? Anyone use them? What do you think of them?
Old Nov 29, 2004 | 06:19 AM
carta79's Avatar
carta79
Life after death
I have the Energy Suspension bushings on my Teg. It made my ride a tad bit stiffer which is what I wanted anyways. I'd recommend them, BTW why post this in the basement and not the Integra forum. You would get better replies in the Integra forum.
Old Nov 29, 2004 | 06:24 AM
ISP James's Avatar
ISP James
DAMIMRED
yeah its worth it.... but its gonna take some work to do the installation yourself.... or some money to have somebody else do it.
try a search there is a ton of info about energy suspesion or prothane bushings ....
Old Nov 29, 2004 | 06:26 AM
Tobra's Avatar
Tobra
It will really sharpen up your handling. Did it on the bug, have not gotten round to it on the teg
Old Nov 29, 2004 | 06:30 AM
slvrteg's Avatar
slvrteg
big boys toys
didn't realize i was still in the basement. Thanks for the opinions. Might re-post in integra forum
Old Nov 29, 2004 | 07:31 AM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
The only problem I hear is the rear control arm bushing binding if not properly greased ALL THE TIME. I have the ES bushing kit too and definitely a better improvement, but I might replace my RCA with a Mugen or OEM type.
Autocross Help Page
Old Nov 29, 2004 | 07:44 AM
AP2's Avatar
AP2
Moderator Alumni
If you're going to use polyurethane, grease it liberally or else you'll go deaf from all the squeaking.
ISP James's Avatar
ISP James
DAMIMRED
is said bushing greasable? i cant imagine it binding anyway but once its installed, if it isnt equipped with a greasable fitting, this cant be true...
Old Nov 29, 2004 | 10:11 AM
carta79's Avatar
carta79
Life after death
I greased my bushings once installed and that's it. Also I would have to disagree with greasing the bushings "All the time". I've been driving sixth months on Polyurethane bushings with no noise issues.
-Wurth lubricant spray is the shiznit.
Old Nov 29, 2004 | 10:37 AM
DakarM's Avatar
DakarM
I'm pretty sure civicsiracer has had his for a while longer than 6month. Also he autoxes so that probably effects it as well.
'00 Dakar Bus CRS Edition
LCD Squad #0001
Originally Posted by WiLL
