high rpm problem
Old Nov 13, 2004 | 03:10 AM
atifali's Avatar
atifali
Default high rpm problem
i got problem with hight rpm like 65mile on 3000 rpm is there any way i can reduce the rpm to normal 2500 it's 91 with intake
Old Nov 13, 2004 | 05:38 AM
bluetwo's Avatar
bluetwo
Relevance is irrelevant
and you don't have a check engine light? ................
some of the sensors will make the ecu run the fuel at a default setting which is at a much higher rpm.
Or you could have your throttle cable too tight, or it may be something I don't know about.
I am not all that familiar with that engine.
Old Nov 13, 2004 | 06:56 AM
George Knighton's Avatar
George Knighton
I think that some of us might be having a problem understanding what you're saying.
If you could tell us a little more in detail about your car and what's happening, that would be appreciated.
You're posting from close to Windsor, so one would normally surmise that English is your first language but, just in case it's not, go ahead and post in French and we will translate it.
Old Nov 13, 2004 | 09:55 AM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
let off the gas pedal? maybe thats what your gear ratios are and you wouldnt really be able to help that.
Old Nov 13, 2004 | 10:27 PM
bbasso's Avatar
bbasso
I guess your driving an ITR, If so there is nothing easy to change that, If you want lower Rpms at cruising speed your can change the 5th gear or swap the tranny for a lessor model. Now I would not reccommend that becuase Honda set the ITR up just right and you will loose a bunch of proformance.
Old Nov 14, 2004 | 04:37 AM
George Knighton
After reading some of the other replies, I gather that I was being a bit dense and that you are complaining about the RPM your car turns at a given miles per hour.
Unfortunately, it's a part of the car's overall performance profile that high RPM is a part of how we get that power and performance. Most ITR drivers wouldn't really mind a car that was turning 3000 RPM at 65 miles per hour, although that doesn't sound quite right for the typical ITR motor.
You could think about putting a GS-R fifth gear in your ITR transmission, as some people have, but you are affecting the car's ability to perform at high speeds, because the performance relies on the car's ability to use the high RPM momentum to get onto the cam quickly.
You might just have the wrong car for what you want out of a car.
it's 91 with intake
This part of your post still puzzles me.
Old Nov 14, 2004 | 11:16 AM
dustimus's Avatar
dustimus
Better golfer than you
maybe he meant to put it in the civic forum or something :dunno:
Old Nov 14, 2004 | 11:28 AM
George Knighton
I dunno. But I'm sure curious about it, now.
Old Nov 14, 2004 | 06:24 PM
dustimus's Avatar
dustimus
maybe there were JDM INTEGRA TYPE R's back in 91 and we just don't know about it!! :exnbp:
Old Nov 15, 2004 | 09:15 AM
bbasso's Avatar
bbasso
I take back what I posted
91 with intake...
91 what?
with what intake?
