Converting Base RSX radio to Bose 6-disc changer possible?
Need help.... Is it possilbe to remove the base Acura RSX radio and replace it with the Bose 6-disc change unit using the same wiring harness? (if I do not care about using the sub). Thank you.
the Bose deck does not put out much of any power, because bose systems use an external amp... so it just sends a very low level signal to the bose amp. If you put it in your car you wouldnt hear much of anything from the speakers. Your best bet to get a 6 disc changer is to add an Alpine M-bus changer with an adapter (total about $300 new).
