Converting Base RSX radio to Bose 6-disc changer possible?
Swapping factory RSX CD to factory Bose 6-disc changer possible?
Need help.... Is it possilbe to remove the base Acura RSX radio and replace it with the Bose 6-disc change unit using the same wiring harness? (if I do not care about using the sub). Thank you.
Older Honda Fanatic
the Bose deck does not put out much of any power, because bose systems use an external amp... so it just sends a very low level signal to the bose amp. If you put it in your car you wouldnt hear much of anything from the speakers. Your best bet to get a 6 disc changer is to add an Alpine M-bus changer with an adapter (total about $300 new).
