turbo D16A1?
Old Jul 30, 2004 | 03:44 PM
T4TURBO's Avatar
T4TURBO
Default turbo D16A1?
can i turbo charge my 89 ls integra? if not, is there any other way to get alot of horse power out of that motor?
Old Jul 30, 2004 | 03:53 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
:a: Yes, it's possible. But it's certainly not your only option...
Considering the age of the chassis, there are a hell of a lot of other issues that ought to be dealt with. Namely, subframe bushings, dampers, springs, tires, driver skill, etc.
Old Jul 30, 2004 | 03:59 PM
T4TURBO's Avatar
T4TURBO
so are saying i should do this first?
Old Jul 30, 2004 | 04:02 PM
TheOtherDave™
Apathy Kills
Do what first? Define "this" if you would, please...
Old Aug 3, 2004 | 10:23 AM
T4TURBO's Avatar
T4TURBO
should i replace the springs bushings tires etc before i get the turbo?
Old Aug 3, 2004 | 11:00 AM
bart_dood's Avatar
bart_dood
Replacing the bushings and springs etc will make a big difference to how to car drives, it will feel better than a new car, its a good place to start before you think about turbo charging, after all would you really want to drive a high powered front wheel drive turbo that had worn out suspension etc? It would take the fun right out of it. Start with the bushes/shocks etc and have some fun now and then look around for a turbo kit.
Old Aug 3, 2004 | 11:17 AM
TheOtherDave™
Apathy Kills
And furthermore, a lot of remedial work will be needed to reliably turbocharge a 15 year old motor. In the end, if you decide to pursue forced induction...a newer SOHC VTEC D16Z* may be a better candidate than your stock motor. It all depends on the amount of power you're looking for, the budget you're bound to..and how reliable you need the car to be.
For now, tighten up the chassis, freshen the bushings all-around, get some light, strong wheels and quality tires on the car...it will help immensely.
Old Aug 3, 2004 | 12:39 PM
Kai's Avatar
Kai
Rotorphile.
It's a serious PITA to get that engine into that body.
The exhaust manifold pattern is the same as later D-series engines, so a basic "homemade" turbo kit can be made to fit.
Old Aug 3, 2004 | 02:36 PM
TheOtherDave™
Apathy Kills
No kidding? :shocked: I figured it'd be a snap..h:
Okay. I officially retract my comment about going with a D16Z*.
Old Aug 3, 2004 | 03:07 PM
Kai's Avatar
Kai
Rotorphile.
Yeah, the D16A1 used the mount pattern of the browntop ZC/ 84-87 D-series engines. With the '88 Civic revision, D-series engines started using a different standard mount pattern... the '89 Integra was the last car to use the 'old' style. The most significant difference is the driver's side mount.
