installing components, any tips?
Old Aug 7, 2002 | 03:36 AM
ludaChris's Avatar
ludaChris
i33t0 n00b
Default installing components, any tips?
i just got my components and planning to install them this weekend. anyone have any tips before i install them?
Old Aug 7, 2002 | 05:36 AM
igo4bmx's Avatar
igo4bmx
CockBlockerator
don't poke a hole through the woofer
Old Aug 7, 2002 | 05:53 AM
VRGNCD5's Avatar
VRGNCD5
cause it's tight!
If putting in front doors, use baffles for the woofer, flush mount the tweeter, surface mount looks:ghey: The baffles will help protect the woofer from the elements, dirt, water, air, even help block out some road noise too. What kind of components did you get anyways?
Old Aug 7, 2002 | 07:07 AM
b00gers's Avatar
b00gers
be very patient.
Old Aug 7, 2002 | 11:13 AM
JJJ784's Avatar
JJJ784
No Soup For You!
what do you use to drill the hole for the tweeter? where did you put the crossover?
Old Aug 7, 2002 | 02:48 PM
ludaChris's Avatar
ludaChris
i33t0 n00b
crystal mobile audio components. i'm a noob...what's a baffle? oh yeah i have a 96 accord. i was wondering where to put the xover and tweeters too. i don't know i guess i'll find out everything when i take things apart this weekend.
Old Aug 7, 2002 | 04:02 PM
Screwdriver's Avatar
Screwdriver
you need to make sure it fits , if not - you can ask for audio advice from your local audio store.
you might need spacers for depth and maybe to cut the plastic protectors at the rear.
Old Aug 7, 2002 | 04:36 PM
VRGNCD5's Avatar
VRGNCD5
cause it's tight!
Good choice. A baffle is basically a housing of sorts (the one's im buying off Will are foam) that will protect the speaker from the elements and help block some of the road noise when used in doors too. I would say put the tweets right in front of the door handles. The crossover should be installed in the door panel right by the woofer.
Old Aug 7, 2002 | 05:01 PM
ludaChris's Avatar
ludaChris
i33t0 n00b
on the accord are those tweeters on the dash? i see 2 small grills on each side.
Old Aug 7, 2002 | 06:22 PM
b00gers's Avatar
b00gers
you can keep them on the dash, or drill a hole in your door panel.
you will probably have to cut the back of the baffle out because of the depth of the speaker. you will know once you start installing.
