reuse oil filter a problem?
i just changed my oil but totally forgot to change the filter after draining the oil first..so how bad is it to reuse a filter for an extra 3k?..am i fine or will it affect the car alot?
let the car sit and let the oil drain back into the oilpan. remove just the oil filter and put in a new filter. you may lose some oil not much at all.
just replace the filter
Originally Posted by qtiger
Depends on the filter. If it's FRAM or some crap, change it now.
I really would change the filter, seriously. All filter are designed with a pressure valve that open when the filter media is loaded up with crap. When that valve opens, the engine oil will bypass the filter media entirely. :eek3: Granted, it's necessary to ensure consistent lubrication, but it also means you have removed any protection afforded by the filter. And buying a new filter later won't undo that damage to your engine. Unless you are truly dead flat-broke (as in buy a filter or buy food), buy a quality filter like a Mobil-1 or Hastings™ brand filter and change the filter in conjunction with the oil.
Your car deserves it.
h:
Originally Posted by NorCal DC4
A FRAM filter shouldn't be on the car in the first place IMO. :a:
h:
h:Thread
