low oil pressure problem
Old Jul 22, 2003 | 01:14 PM
whiteinte95's Avatar
whiteinte95
Default low oil pressure problem
Just installed my oil pressure gauge . removed stock sensor and i installed the fitting with teflon tape and there is no leaks. With the car at normal operating temp, guage is at 8psi at idle and 27 psi at 3000 rpm. I know the car burns oil but there is no leaking at all. What could cause this low pressure? oh ya, car is 95 gsr
Update. just changed oil, went with thicker 10w-40 and rsx oil filter hoping to raise oil pressure, there was no change
Old Aug 10, 2003 | 09:15 PM
sunshine's Avatar
sunshine
Torqueless Wonder
Low oil pressure might be from lower end problems. Give us some history on your motor. Ever blow it? Over rev it? Boost on it? Mods?
