is it time for new brake pads?
Old Apr 25, 2004 | 07:49 PM
Jason Moon's Avatar
Jason Moon
Default is it time for new brake pads?
when i press the brake lightly, the brake starts to squeal. but when i press it hard, it doesnt squeal. does this mean that the pad is almost dead? The pads that i have arent made for autocrossing nor racing, just street pads for me to drive around the street and stop accordingly. any ideas?
Old Apr 25, 2004 | 08:08 PM
cheezthis's Avatar
cheezthis
sound/acoustical engineer
Look at the pad and see how much is left first.
Old Apr 26, 2004 | 05:02 AM
nsxtasy's Avatar
nsxtasy
Here's how you can check your brake pads yourself.
The brake pad consists of two flat pieces bonded together. One is called the "backing plate" and is a piece of metal about a quarter of an inch thick. The other, the stuff between the backing plate and the rotor, is called the "pad material", and this is what wears out.
When brake pads are new, the pad material is about 11 mm thick. When the pad material is about 2-3 mm thick, it's time to replace the pads. If it gets that thin, you will start to hear a squeaking sound (which you might hear even when you are not stepping on the pad), which is a metal tab on the inside pad that starts to come into contact with the rotor when the pads are that thin.
On the ITR, you can look through the spokes of the wheels and see the top edge of the outside brake pad, even without taking off the wheel. If you're not sure about how to do this, ask your favorite "car nut" to show you. Most such folks can show you how, even if they're not familiar with the ITR. Just show them these instructions.
Stand above the wheel, looking down through the spokes of the wheel to the top of the caliper (the big metal holder on the side of the rotor, which is the big metal disk inside the wheel). A flashlight will help. At the top, inside the caliper, you will see the edge of the brake pad - the metal backing plate and the pad material.
This method isn't totally thorough to check for worn pads, because sometimes the inside pad (which you can't see through the spokes of the wheels) wears slightly faster than the outside pad, so if the outside pad looks plenty thick, you would still need to remove the wheel to be totally thorough about it. But if the top of the outside pad is worn down to a thickness of about 2-3 mm or less, then you know that it's time to replace the pads.
Old Apr 26, 2004 | 11:07 AM
TheRooster's Avatar
TheRooster
Former Senior Member
If in doubt, change 'em out.
Most pads come with a soft metal tang on the side of the pad. If the metal tang is touching the rotor, like an oil light being on, it was time to action before now. The tang is purposefully made of a soft alloy so that it wears instead of your rotor, and still lets you know that your brakes would really like to be changed.
Take a look at yours and if the tang is rubbing, or getting close, you should probably consider new pads.
Old Apr 27, 2004 | 08:19 PM
XSrcing's Avatar
XSrcing
yes, it means that you are at about 1.7 mm on the pads. the squealers will start going nuts around 1.6mm.
CapYoda
92+ Civic/EL & Del Sol
15
Nov 12, 2006 09:57 PM
ls_draco
11
Aug 27, 2003 06:12 PM
GSRguy
5
Jul 3, 2003 10:15 AM
