oil pan gasket replacement help
Just noticed a few days ago that my gasket is leaking. Has anyone changed it themselves? I saw they were alot of screws that look easy to take out but there are two that looks like it may be under the transmission? Any suggestions?
Thanks
Thanks
You gotta take off the exhaust A-pipe, & take off that cover plate over the bottom of the flywheel. If it's a GSR you've got a couple braces between the tranny & the block. But it's still just nuts & bolts - not too hard.
Open up the gasket & lay it out flat for a day or 2. That way it's not trying to curl up when you try to put the pan back on...
I need to do this on my wife's Accord next time I do her oil change.
Make sure you drain the oil real well first. Then do what was posted above. When I get home I can post the torque specs on the bolts to the pan...unless someone beats me to it. I can't remember if you need Honda Bond as well so I will post that as well when I am done with work.
Yea it is a GSR. IS the cover of the bottom of the fly wheel black? because that is what I am worried about. I think that is the cover because I can see 2 bolts under it that is holding the pan on.
Thanks
Thanks
Thanks
Thanks
First a couple braces, #9 & #10.
Then the cover plate, #1.
I was installing my Greddy header when I noticed that two of those bolts were missing. No leaks, so I didn't take the opportunity to replace the oil pan gasket. I don't remember if I used Loctite Blue when installing new bolts....
