Compression Test 220 across the board
Old Mar 10, 2004 | 12:09 AM
blue-streak's Avatar
blue-streak
well i visited california this weekend and had to fly back but there is a deposit on the car and the seller went to go get it inspected for me and he told me that everything was fine, but the horn was disconnected because of the jdm conversion? (thats what he was saying) if this IS true could i able to connect it back?
he also said that they did a compression test and it read 220 220 220 220 is that about right on a stock itr?
edit: i also will be receiving the fax tomrrow
Old Mar 10, 2004 | 02:13 AM
BudMan
Guest
Posts: n/a
I've never seen a car yet that read exactly the same compression in each cylinder. Someone makes a claim like that, I'd like to see them redo the test in front of me. **~220 is reasonable for a pressure**
just my .02.
Old Mar 10, 2004 | 02:36 AM
nightrider's Avatar
nightrider
i don't see why you would post the exact same thread on here when you did on HT last night and got your answers. :roll: don't worry about the compression being the same in all cylinders because that's a positive thing. make sure to check over the inspection report because 220 all across the board is really good and you may be lied to. oh, and yes your horn can be hooked back up.
Old Mar 10, 2004 | 04:53 AM
George Knighton
Guest
Posts: n/a
That's excellent, if you can trust the tester. Not to make you paranoid, or anything. LOL...
How many miles on this car?
Old Mar 10, 2004 | 04:54 AM
George Knighton
Guest
Posts: n/a
Originally Posted by nightrider
i don't see why you would post the exact same thread on here when you did on HT last night....
Maybe because a few people don't look there?
Old Mar 10, 2004 | 02:50 PM
blue-streak
well i saw george's farewell to h-t and id like to see his reply :P
car has 28k miles
and i was wrong about 220 on all it was 220 225 220 220
i just wanted to get much replys from peopel thats why i posted here and h-t
Old Mar 10, 2004 | 03:42 PM
nightrider's Avatar
nightrider
car has 28k miles
well, i understand you wanting George's reply then. anyway, with your numbers, you're looking at a good motor. as long as there aren't big differences between the cylinders, you're in the clear.
Old Mar 10, 2004 | 03:57 PM
blue-streak
from seattle? D:
should meet up sometime and have a photoshoot if i get that car
