will I be safe with this offset?
Just another import lover
Hey guys, getting some new rims in a couple of weeks. Just a question>> I'm wondering if a +40 offset, with my suspension/lowering setup, will be acceptable? I have koni yellows and neuspeed springs. 1.75" F/ 1.5" R
I have a set of 17" konig troubles(new for this year), and a 40 series kumho 712 tire to go along with it
I was just worried about some rubbing that might occur.
Honorary Moderator Alumni
+40mm offset on what size wheel and what size tires?
You can't just say yeah that will work if you don't know the dimensions of the wheel and tire.
Autocross Help Page
Autocross Help Page
Yes, i drive a civic
you should be safe with a 40 series tire, thats pretty thin. but i remember having trouble with the inner plastic lining in the wheel well when i had my 17's on 205-40's in my cr-ex. but as long as your springs keep their bound and rebound. and shocks are in good shape you should be fine. i would have some conscern if you had like a 3" drop or more.but should be fine.
Excellent, thanks bro. This is what I'm thinking. I had some doubts about the inner wheelwell if I chose more then +40. I was thinking +42 because I was worried about the fender but.......
anyone else??
anyone else??
Well you didn't answer my 2nd part of the question. What size are the wheels. You could have a 17x8" wheel with 40mm offset and that will not work.
Autocross Help Page
Autocross Help Page
you should be fine. im running a 2.5 inch drop with some 35+ offset. no problems yet h:
