will I be safe with this offset?
Old Mar 26, 2004 | 06:21 AM
alllooksnnogo's Avatar
alllooksnnogo
Just another import lover
Default will I be safe with this offset?
Hey guys, getting some new rims in a couple of weeks. Just a question>> I'm wondering if a +40 offset, with my suspension/lowering setup, will be acceptable? I have koni yellows and neuspeed springs. 1.75" F/ 1.5" R
Old Mar 26, 2004 | 06:32 AM
Wharbone's Avatar
Wharbone
It should work fine. What size wheels are you getting?
Old Mar 26, 2004 | 06:37 AM
alllooksnnogo
I have a set of 17" konig troubles(new for this year), and a 40 series kumho 712 tire to go along with it
I was just worried about some rubbing that might occur.
Old Mar 26, 2004 | 09:22 AM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
+40mm offset on what size wheel and what size tires?
You can't just say yeah that will work if you don't know the dimensions of the wheel and tire.
Autocross Help Page
Old Mar 26, 2004 | 10:29 AM
alllooksnnogo
205/40/17"
Old Mar 26, 2004 | 10:36 AM
forcfedcivic's Avatar
forcfedcivic
Yes, i drive a civic
you should be safe with a 40 series tire, thats pretty thin. but i remember having trouble with the inner plastic lining in the wheel well when i had my 17's on 205-40's in my cr-ex. but as long as your springs keep their bound and rebound. and shocks are in good shape you should be fine. i would have some conscern if you had like a 3" drop or more.but should be fine.
Old Mar 26, 2004 | 10:42 AM
alllooksnnogo
Excellent, thanks bro. This is what I'm thinking. I had some doubts about the inner wheelwell if I chose more then +40. I was thinking +42 because I was worried about the fender but.......
anyone else??
Old Mar 26, 2004 | 05:08 PM
CivicSiRacer
Well you didn't answer my 2nd part of the question. What size are the wheels. You could have a 17x8" wheel with 40mm offset and that will not work.
Autocross Help Page
Old Mar 26, 2004 | 05:33 PM
forcfedcivic
since 17x7 is the most common i just assumed. but yeah good point CivicSiRacer. what is the width of the rim.
Old Mar 26, 2004 | 08:33 PM
asiandoood's Avatar
asiandoood
sancho on the sizzide!
you should be fine. im running a 2.5 inch drop with some 35+ offset. no problems yet h:
