camber help
camber help
i have a couple of questions regarding camber kits.
first, how hard are they to install?
seccond, would they carry them at an alignment shop?
and third, does neone kno where i could front and rear cambers for a 99 civic as cheap as possible.
i though i would lower my car 2.0 but ive had it a 2.5 for a while, and i already see tire ware after 1month, so imma get some cambers, and need some advice. thx
NASA-VA Hyper-Announcer
Did you get an alignment after you lowered your car? Camber wear will not show in a month, more than likely your Toe settings are out and that will wear tires very quickly.
David who sounds like a broken record here sometimes..
does the camber kit correct ur toe settings and is it easy to install. If so am i better off waiting to put on my Tein s-tech springs (1.9in drop in -F- & 1.7in drop in -R-) and Koni Yellow Sports untill i get a camber kit. Do i need camber adjust for both front and rear. Its a 2000 civic hatchback? Xplicid01 i just bought springs and shocks from www.optauto.com they have very good prices on things or u could talk to WestCoastStyle a lot of people buy from him. For Cambers imma get it from him prob. GL MAN SRRY FOR THE THREAD JACK!!!
You shoud not need a camber kit, toe is adjustable from the factory so there is not kit for it, I run -2.5 camber in the front and -2.0 camber in the rear and I have gotten 35000 miles out of my last set of tires, when I took them of the inside was bald and the outside of the tires was at the wear bars which I Consider pretty even wear.
teaminspire
09-15-2002 11:42 PM
