removing steering wheel- HELP!
Old Mar 18, 2004 | 05:15 PM
bigt61's Avatar
bigt61
Default removing steering wheel- HELP!
how do I remove the steering wheel? i have to remove it - just the wheel itself. not the column.
Old Mar 18, 2004 | 05:37 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
take the plastic covers off each side
you can see that there is a bolt on each side, but you have to use a star tool to remove them
remove the yellow wiring clip for the SRS/airbag.
That's about it.
Old Mar 19, 2004 | 07:04 AM
bigt61's Avatar
bigt61
kool. so after i remove the SRS airbags, i can see the screws or whatever to take off and get the wheel off?
Old Mar 22, 2004 | 05:30 PM
bigt61's Avatar
bigt61
bumpety bump bump help please!
Old Mar 22, 2004 | 05:44 PM
Kai's Avatar
Kai
Rotorphile.
If the 3G Integra has a wheel like a 5G Civic, which it should, after you remove the airbag there is a large nut that holds the wheel on. Undo that, and you can sometimes pull the wheel off by hand. If not, you need a harmonic balancer/steering wheel puller.
Old Mar 22, 2004 | 06:04 PM
IntegraR's Avatar
IntegraR
Remove center pad of steering wheel.
Remove steering wheel shaft nut.
Remove steering wheel by rocking it slightly from side to side and pulling back steadily.
Reverse procedure to install. Torque steering wheel shaft nut to 36 ft. lbs.
crxforum
CRX & Pre 92 Civic
3
Mar 15, 2004 09:22 AM
Ochdx
92+ Civic/EL & Del Sol
13
Mar 8, 2004 06:44 PM
3 plus 1
Jun 27, 2003 01:20 AM
HardSpike
Accord
4
Mar 8, 2003 01:26 PM
jschmid
Accord
10
Aug 26, 2002 04:59 PM
