11:1 CR Pistons in F22B1?
Old Mar 5, 2004 | 06:55 AM
lingerbw's Avatar
lingerbw
Default 11:1 CR Pistons in F22B1?
Alright guys, I need some expert advice here. What will the impact be of switching to a 11:1 piston in my F22B1? Are stock rods safe for this compression ratio? Will I run into detonation problems (even if I run a colder plug and 93 octane)? What other considerations are there when jumping up so much in compression? I really need some of you all-motor guys to respond with some sound advice.
I have had a 3-angle valve job, port and polish and intake manifold port matching on the top half. Also milled .008 (to make it flat again after a blown head gasket).
Thanks for any direction you can provide.
-Brent
Old Mar 5, 2004 | 09:36 AM
qtiger's Avatar
qtiger
Stock rods will be fine, but I would suggest that you upgrade them. IIRC, F22 rods are quite weak. If you decide to keep stock rods, add ARP rod bolts.
Detonation will not be a problem with normal temp plugs and 91+ octane.
Old Mar 5, 2004 | 09:50 AM
lingerbw's Avatar
lingerbw
So, you see no issues with installing these pistons? I take it that the ARP bolts are just a stronger bolt? To be honest, I can't afford new rods right now. As long as I don't do something stupid, like boost it with that compression, I should be ok?
Old Mar 5, 2004 | 10:20 AM
ludeboom's Avatar
ludeboom
u may want to change your cam to maximize performance
but otherwise the fuel octane and ignition timing settings are your main concern. also, u may want to raise fuel pressure, unless you get injectors.
~boom
Old Mar 6, 2004 | 06:45 AM
lingerbw's Avatar
lingerbw
~boom
Thanks for the response. As far as damage to engine internals, if I run high octane fuel, and set the timing appropriately, it seems like there shouldn't be any premature wear on the motor. Am I correct in this assumption? What about rod bearings? Just replace with stock when putting the motor back together?
Anyone else see any red flags with this project?
Old Mar 6, 2004 | 08:46 AM
PHiZ's Avatar
PHiZ
BOOST GOD
I would suggest some kind of fuel managment.
-PHiZ
Old Mar 6, 2004 | 10:16 AM
qtiger's Avatar
qtiger
Honestly, I'd be tempted to wait on a rebuild until you could afford rods. With the redone top end, rods are going to be your only weak point rev-wise.
Old Mar 7, 2004 | 04:42 PM
lingerbw's Avatar
lingerbw
-PHiZ
Yeah, I thought about that, too. But I can do that after I put this thing back together. Right now my big concern is getting the internals right. Just for info, though, what type of management are you talking about? Like a VAFC, or more along the lines of fuel quantity upgrade (injectors, pump, rail)?
Old Mar 7, 2004 | 04:48 PM
lingerbw's Avatar
lingerbw
Aaaahhh... you're killin me
I want to drive the car this summer (hopefully by the end of the month, actually). Don't get me wrong, I want input like this, but are you coming from a track/racing perspective, or do you think rods are a necessity just for some occasional fast accelerations onto the highway? What if I were to keep the revs at/below redline?
Thanks qtiger, keep it coming, man. I need all the advice I can get right now. This is the critical decision making stage!!
Old Mar 7, 2004 | 07:10 PM
ludeboom's Avatar
ludeboom
i hardly think the rods will be your main concern with the rev limit. the head, especially a SOHC head is going to have trouble getting the job done. you will probably pop a spring before 8000, maybe lower.
~boom
